Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The rotating side brush is no longer rotating
I've unscrewed the screw that holds the brush in place, removed the brush, cleaned the area, and reinstalled the brush without success.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
As it appears that you've already taken a few easy steps without success, there is most likely something wrong with the side brush motor assembly.
Luckily an awesome Ifixit contributor has created a guide on replacing it!
it can be found here:Changement moteur de brosse latérale iRobot Roomba 630
while the model number is different it shares the same construction and should still work.
Hope this is helpful!
Indice 0
2 commentaires:
Thanks! I've ordered a replacement motor. Hopefully that will do it.
par
It worked :)
par
Ajouter une réponse
Carorhoomba sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 34
Total : 253
