number 3 clip broke
I was reinstalling the #3 wire and thre clip on the logic board broke. How do I fix it
trey, if you are talking about the locking clip, that can be very tricky. You can try and find the clip on another phone and use a magnifying source to try to attach it. It is removed by squeezing the ends carefully and then gently removing it one side first. Its not easy and requires good eyesight and a steady hand. If it is the connector that is broke, your will require a steady hand, a good knowledge of SMD soldering and the right tools. You could try and contact user "hectordtruong" on here. His email is in his profile. He does board level repair and apparently is an Ace at it. Hope this helps to get you started. Good Luck.held in by the
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 322
