Aller au contenu principal
Pourquoi le moteur de mon téléphone sache d'allumer
Il était tombé dans l'eau après une 15 minutes si je l'allume ça ne marche même pas et les gens dises que c'est le moteur
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Aider moi svp
par
Ajouter un commentaire
1 Réponse
@abdoulba93206 for now you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The next thing to do is to clean it. since iFixit does not yet have guides for this model, disassemble your phone using something like this video as your guide. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more.
For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned with an ultrasonic cleaner.
Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Translation
@abdoulba93206 Pour l'instant, tu dois arrêter d'essayer de charger, de synchroniser ou d'utiliser ton téléphone. Cela pourrait aggraver une situation déjà difficile. Cela pourrait endommager davantage ton téléphone.
La prochaine chose à faire est de le nettoyer. Comme iFixit n'a pas encore de guides pour ce modèle, démonte ton téléphone en utilisant quelque chose comme cette vidéo comme guide. Examine attentivement et de près tous les composants et connecteurs. Évalue vraiment les dommages. Recherchez les traces de corrosion importantes, évaluez les broches des connecteurs, etc. Examinez tous les connecteurs ainsi que les extrémités des câbles. Vous devrez retirer tous les blindages EMI. Si vous ne retirez pas les blindages, vous ne nettoyez pas la carte. Une fois que vous avez nettoyé la contamination grossière, utilisez de l'alcool isopropylique à 90 % et nettoyez encore un peu vos pièces.
Pour un nettoyage correct, utilise ce guide. Il a été écrit pour un iPhone 3G d'Apple, mais il est également pertinent pour ton téléphone. Je ne saurais trop insister sur l'importance d'un bon nettoyage, alors recommence encore et encore en remplaçant l'alcool après chaque nettoyage. N'utilise pas d'air comprimé pour le nettoyage, car cela peut entraîner des liquides ainsi que des particules de corrosion dans des zones qui causeront des problèmes plus tard. Tu n'as pas besoin de le laisser sécher pendant une journée. L'alcool isopropylique à forte concentration s'évapore rapidement et dissipe l'eau. L'important ici est le nettoyage. Il serait bien sûr préférable de le faire nettoyer par un professionnel avec un nettoyeur à ultrasons.
N'oublie pas de remplacer la batterie. C'est une obligation et non une option. Elle tombera en panne si tu ne t'en occupes pas maintenant. Après cela, remonte ton téléphone et réévalue la situation. Tant que tu n'auras pas nettoyé ta carte et remplacé la batterie, tout n'est que supposition. Garde à l'esprit que les dégâts causés par l'eau sont les plus difficiles à diagnostiquer et à réparer. Peu importe si l'eau a été exposée pendant 2 secondes ou 2 heures, ce qui compte, c'est l'endroit où l'eau (les particules) a causé les dégâts.
Indice 0
Ajouter une réponse
Abdoul Ba sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 12
