Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La mise à jour de mars 2015 du MacBook Air 11" d'Apple est dotée de processeurs Intel Core i5 et i7 de cinquième génération, offrant ainsi une légère amélioration des performances et de l'autonomie de la batterie.
Keyboard or trackpad failure (Unit 1)
Previously working fine without any issues and have just been stored for some time unused only to occasionally give some charge to keep battery health.
Clean installation OS 12.7.6 Monterey & new batteries.
No evidence whatsoever of water damage.
Tested with a couple of new touch pad cables.
All keys seems to be working fine QWERTY 123 etc....
Touch pad seems to have all features working.
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires:
What is not working? The Trackpad or the Keyboard or both?
Using an external keyboard and mouse go into About This Mac > System Report - Click on Hardware to expand and jump to USB section . Click on the section heading looking for where the Keyboard / Trackpad is listed, click on it and take a snapshot of the lower section expanded out.
par
@danj The internal KB & TP's seems to be functioning OK providing I get a second where the menus aren't popping up and down or flashing (2 units showing very similar symptoms) very weird, immaculate condition insiade and out both.....
par
Ajouter un commentaire
1 Réponse
So you have ghost touch syndrome! This is a trackpad issue when moisture (cleaning liquid) has entered into the membrane sandwich. See if a hair dryer warming up the trackpad fixes things.
Indice 0
4 commentaires:
I don't have a hair drier but I do have a heat gun...... I will try at say 80 degrees to see if it helps or should I go higher? Internal inspection all looks perfectly well....
par
@livfe - Hopefully lower if it hurts you it’s too hot.
par
@danj I will swap out the track pad and see if that cured it when I have a spare floating around.
par
I finally got back to this and have changed over with 3 track pads and 3 TP cables and it still has this flashing effect. Turned off auto hide the dock and restarted. Tried everything even with another SSD with Monterey on it (Clean Instal) and it still flashes. Great.
par
Ajouter une réponse
livfe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 18
Total : 293
