Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Modèle début 2011 : A1278 / processeur 2,3 GHz i5 ou 2,7 GHz i7
Would any missing parts cause the fans to run at full speed?
Hallo, I'm attempting to revive a 2011 13" Unibody (A1278) that's missing pretty much all its internal parts. Right now it only has a logic board, fan+ heatsink, battery and the antennas hooked up, in a shell with a broken screen attached. Other than a new cable for a drive it doesn't need any more parts because I intend to use it as a headless server, and I have managed to get it to boot and display to an external screen, but the fans run at full speed the moment I switch it on. Does anyone know if any of the components I'm missing have a temperature sensor that the board is upset it doesn't have? Or would this be a fault with the board itself? The CPU has been repasted so I doubt it's overheating.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Okay, so by doing some research I have found out that there is a temperature sensor in the trackpad (Source), so I will order a new trackpad for it and see if that fixes it. Guess I shouldn't have given up on my research so soon, PROBABLY solved.
Indice 1
Ajouter une réponse
Snale sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 193
