Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Compaq Presario CQ60-211DX. Cet ordinateur portable est doté d’un écran de 15,6 pouces, d’un clavier complet et d’une mémoire vive de 4096 Mo. Le Compaq Presario CQ60-211DX n’est plus commercialisé et ne peut être acheté qu’auprès de revendeurs.
Pourquoi mon ordinateur ne veux plus se chargé
J'attends une 1h mais sa veut pas se chargé ou sa charge mais sa ne s'allume pas
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
@zenox start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc. use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Use the for that. sorry, I only have an English version. Once opened, post some good pictures of what you see with your Question or as a new answer. That way we can see what you see.
Of course, it is also possible that this is a bad RAM. Remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
Let us know what you find out.
Translation
@zenox commence par les choses faciles. Déconnecte l'ordinateur de l'alimentation en débranchant le cordon d'alimentation de ton ordinateur. Déconnecte tous les périphériques externes de l'ordinateur. Retire la batterie. Maintenant, appuie sur le bouton d'alimentation pendant environ 30 secondes à 1 minute. Raccorde l'adaptateur secteur et regarde si ton ordinateur montre un signe de vie.
Ensuite, tu veux vérifier ton alimentation électrique. Assure-toi qu'elle a les bonnes tensions. Vérifie que les connecteurs ne sont pas pliés, etc. Vérifie la prise d'entrée CC de ton ordinateur portable. Assure-toi qu'il n'y a pas de corrosion, de débris, etc. qui l'empêchent de fonctionner. Nettoie-le de tout débris, etc. Utilise quelques bouffées d'air pour le nettoyer. Si rien de tout cela ne fonctionne, prends un ampèremètre et regarde si ton ordinateur portable tire un quelconque ampérage du chargeur. Ensuite, tu dois vérifier si ta carte mère est même alimentée. Pour cela, tu dois bien sûr l'ouvrir. Utilise le Compaq Presario CQ60 Notebook PC Maintenance And Service Guide pour cela. Désolé, je n'ai qu'une version anglaise. Une fois ouvert, poste de bonnes photos de ce que tu vois avec ta question ou comme nouvelle réponse. De cette façon, nous pourrons voir ce que tu vois. https://fr.ifixit.com/Tutoriel/Ajout+d'i...
Bien sûr, il est également possible que la RAM soit défectueuse. Retire la RAM, nettoie les contacts avec une gomme à crayon. Fais-le délicatement pour ne pas détruire le module. Remets-le en place et redémarre. Si tu as plusieurs modules, retire-les et ne laisse qu'un seul connecté.
Fais-nous savoir ce que tu as découvert.
Indice 0
Ajouter une réponse
zenox sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 59
