Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Also known as a multitester, or a VOM (Volt-Ohm meter), a multimeter is an electronic measuring instrument used to measure voltage, current, and resistance. Includes handheld and tabletop testing devices.
minipa ET-2033B multimeter, turns on but doesn't measure anything
Does anyone have the ET-2033B schematic?
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires:
If I had to guess, I would say it's a broken fuse within the device. You can use this -> https://wiki.sj.ifsc.edu.br/images/3/34/... guide to check inside and see any blown fuses.
Also, I couldn't find any diagrams. Sorry about that.
par
@eduardoadamo
any measurement in particular?
like ohms? voltages?
par
Ajouter un commentaire
1 Réponse
I am not finding many specifics. Can you post a picture of the meter? As mentioned, do any measurements work? Have you tried ohms, AC Voltage & DC voltage? What mode are you in and are your leads plugged into the correct ports?
Indice 0
1 commentaire:
Então amigo, a foto do multímetro no momento não tenho em minha galeria, porém respondendo , não tem medição em nenhuma escala, apenas funciona o sinal de continuidade. Não mede nenhuma tensão, AC/DC, bem como não mede resistências.
A foto do multímetro é fácil na internet.
Medindo os componentes da placa e na placa, não consigo definir o que está errado. Peço ajuda.
Obrigado
par
Ajouter une réponse
Eduardo Adamo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 86
