Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation et le démontage du ROG Ally, une console de jeux portable fabriquée par ASUS. Sortie en 2023 et identifiée par le numéro de modèle RC71L.
Can’t charge at all
As title says, plugged the USB and it didn’t charge at all… no light, nothing. I know battery and everything still works since it still manage to boot up and everything when there’s still charge left. Maybe a dead USBC? Any way these can be replaced? Thanks
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@dafangefull before thinking about replacing the USB-c connector, go through the answers/comments of this question USB-C port not charging with power delivery See if that might work for you as well.
If it does not, then you will most likely have to replace the port. Of course, for that you will need to disassemble it and then finding a replacement port. Use these guides Asus ROG Ally to work on it. This task will also require some decent soldering tools and skills. Let us know what you find out.
Let's see if our game console guru @dan0 has some other possible solutions for your Ally's issues
Indice 1
3 commentaires:
I agree with Oldturkey03, I would first replace the port (it's most likely the port that did fail). If this failed, you might want to check the motherboard. If you can share pictures with us (regarding the USB-C port), that would be awesome.
par
I have this same problem. What pictures would help? It was fine and then stopped taking a charge, it just slowly died and now won’t work anymore even plugged in. We could see the battery draining and couldn’t do anything
par
@douglasforeman I'm going thru this exact issue rn did you figure out how to fix it?😭
par
Ajouter une réponse
Stephen Leli sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 48
Total : 889
