Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La manette Xbox One a été introduite en 2016 lors du lancement de la Xbox One S et ajoute le support Bluetooth pour Windows 10/11. Elle rectifie un nombre de défauts de conception des manettes modèles 1537/1697 et elle est beaucoup plus fiable. Cette manette a été remplacée par le modèle 1914 amélioré.
How can I make it turn on?
It seems a battery exploded inside the port and calcified the connector and it's surroundings. I already cleaned it as best I could with a bit of alcohol but it doesn't seem to register that it has batteries, even though I put in fresh ones. That being said, when I connected it to my laptop through cable it seemed to receive power and turn on.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Hi Alex!
Oh my... The only thing you can do is to clean it with isopropryl alcohol. The whole motherboard, but this is what you already did.
So, the next step is to replace the battery pins for new ones! Soldering is required, but it's not that difficult.
If that didn't worked, then there is something (or more things..) damaged on the motherboard. If this is the case, it's probably not worth to repair it. Sorry.
Hopefully replacing the battery pins will do it!
Indice 0
Ajouter une réponse
Alex Gonzalez sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 132
