Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Dell Latitude 5420 est un ordinateur portable robuste et étanche.
Why account disabled see system administrator?
how can i enable my disabled account on my dell laptop ?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
If your Dell Latitude 5420 account is disabled (e.g., a Windows login account), here are the steps to enable it:
Method 1: Enable the Account via Another Admin Account
  1. Log in to Windows using an administrator account (if available).
  2. Press Win + R, type lusrmgr.msc, and press Enter.
  3. Go to Users in the left pane.
  4. Right-click the disabled account and select Properties.
  5. Uncheck "Account is disabled" and click OK.
Method 2: Using Command Prompt (Admin Required)
  1. Open Command Prompt as Administrator (search for cmd, right-click, and select Run as administrator).
  2. Type the following command and press Enter:
  3. cmd
  4. Copy
  5. Download
net user "username" /active:yes
  1. (Replace "username" with the actual account name.)
Method 3: Reset Password if Locked Out
If the account is locked due to failed login attempts:
  1. Boot into Safe Mode (restart while holding Shift or via BIOS).
  2. Use the built-in Administrator account (if enabled).
  3. Reset the password via:
    • Control Panel > User Accounts > Manage another account.
    • OR use Command Prompt (net user "username" newpassword).
Method 4: Using Dell Recovery Options
If you can't access any admin account:
  1. Restart the laptop and press F12 to enter Boot Menu.
  2. Choose Diagnostics or SupportAssist OS Recovery.
  3. Follow prompts to reset or repair Windows.
Still Having Issues?
  • If it's a BIOS/Dell admin password, you may need to contact Dell Support.
  • For Microsoft account issues, reset it via Microsoft's account recovery.
Indice 0
Ajouter une réponse
theo yeb sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 225
