Mon ordinateur ne s'allume plus
@loickibaniakina we will need to know your exact model number.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
It is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
Connect and external monitor and see if that shows anything different when your laptop starts up.
Let us know how things are working out with each check/test.
Translation
@loickibaniakina, on va avoir besoin du numéro exact de ton modèle.
Commence par les trucs simples. Débranche ton ordi en retirant le cordon d'alimentation de la prise. Débranche tous les appareils externes de l'ordi. Maintenant, appuie sur le bouton d'alimentation et garde-le enfoncé pendant environ 30 secondes à 1 minute. Rebranche l'adaptateur secteur et regarde si ton ordi montre des signes de vie.
Ensuite, vérifie ton alimentation électrique. Assure-toi que la tension est correcte. Vérifie que les connecteurs ne sont pas tordus, etc. Vérifie la prise d'alimentation CC de ton ordinateur portable. Assure-toi qu'il n'y a pas de corrosion, de débris, etc. qui pourraient empêcher son fonctionnement. Nettoie-la à l'aide de quelques bouffées d'air comprimé. Si rien de tout cela ne fonctionne, procure-toi un ampèremètre et vérifie si ton ordinateur portable est alimenté par le chargeur. Après ça, tu dois vérifier si ta carte mère est bien alimentée. Pour ça, tu dois bien sûr l'ouvrir. Publie quelques photos claires de ce que tu vois. Comme ça, on pourra voir ce que tu vois.
Il est aussi possible que ce soit un module RAM défectueux ou un écran LCD défectueux. Retire donc la RAM et nettoie les contacts avec une gomme à crayon. Fais-le délicatement pour ne pas endommager le module. Remets-le en place et redémarre. Si tu as plusieurs modules, retire-les tous et n'en laisse qu'un connecté.
Connecte un écran externe et regarde si quelque chose change lorsque ton ordinateur portable démarre.
Tiens-nous au courant de l'évolution de la situation après chaque vérification/test.
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 112
