Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation, le démontage et le diagnostic de l'iPhone 15, sorti le 22 septembre 2023. Il est doté d'un écran OLED de 6,1 pouces, d'un système de double caméra de 48 MP et d'un port USB-C.
Phone reboots repeatedly after screen replacement
I replaced the screen on an Apple iPhone 15 with an LCD panel. My eyes do not like OLED screens. The panel looks great but the phone keeps rebooting every couple of minutes. I also get a message that the display is not recognized despite having run through the Apple repair routine multiple times. It always says genuine apple part even though it’s not from Apple. Any suggestions. I have looked at the analytics log but it is not logging the crashes.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
In answer to the original question here that I didn't see until now, an LCD replacement screen should not be causing boot loops; if it does either the screen is defective or something was broken or done wrong in the process of replacing the screen.
With any aftermarket screen it is not possible to eliminate the genuine parts message no matter how many times you run the Repair Assistant. It's curious that the utility seems to think you do have a genuine Apple screen even though that's not possible since Apple does not make LCD replacements for their OLED iPhones.
Probably too late to help now, and I know you've said you checked the analytics, but just to cover all the bases, check out the kernel panic wiki page to make sure you're looking in the right place for the right files.
iPhone Kernel Panics - iFixit
If by some miracle you do find a panic log, come on back and post the first page on your question; after that we should be able to diagnose the issue causing the reboots.
One caveat regarding LCD replacement screens that they don't tend to mention is that you're going to find your battery life shortened. OLED screens don't need a backlight since each pixel generates its own light, whereas on an LCD the pixels require a separate light source - i.e., the backlight. So an LCD display will always require more power than an OLED display, meaning your battery won't last as long before needing to be recharged.
Indice 1
3 commentaires:
I'm having the same issue, panic log: {"bug_type":"210","timestamp":"2025-12-17 10:57:28.00 +0100","os_version":"iPhone OS 18.6 (22G86)","roots_installed":0,"incident_id":"C69CB9E4-5DF4-490B-9881-750DFE9D1B85"}
"build" : "iPhone OS 18.6 (22G86)",
"product" : "iPhone15,4",
"socId" : "8120",
"socRevision" : "11",
"incident" : "C69CB9E4-5DF4-490B-9881-750DFE9D1B85",
"crashReporterKey" : "70ff554e2c8eb0257eeaa4ccf623f9f2d752cdbd",
"kernel" : "Darwin Kernel Version 24.6.0: Tue Jul 15 21:53:53 PDT 2025; root:xnu-11417.140.69~16\/RELEASE_ARM64_T8120",
"date" : "2025-12-17 10:57:28.01 +0100",
"panicString" : "panic(cpu 2 caller 0xfffffff035cd8b1c): SMC PANIC - ASSERT: target\/d37\/target.cpp:258: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x100000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n - Misc(2) OUTBOX1 not ready\nASSERT: target\/d37\/target.cpp:258: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x100000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n\nR
par Partager
Update: I tried updating the iOS version to 26.2 via iTunes, but WiFi was too slow before it would restart so it wouldn't do the update. I downloaded the update in iTunes and connected the iPhone there, in iTunes the update failed as well through "unknown error", but at the same time it wouldn't restart again so the only other option was to do a Restore via iTunes. But also that throws an "unknown error" so now I am stuck with a bricked device... Thanks Apple, I guess they succeeded in making it impossible to do your own repairs :(
par Partager
@pieterd73479 Sensor array code 0x100000 indicates a failure of the Front Sensor Assembly. Replacing it will probably result in the loss of Face ID; at this point we don't have any information that the Repair Assistant will restore lost Face ID, but at a minimum it would require you to use a genuine Apple part, whether new or used.
par Partager
The issue was caused by the non-genuine LCD’s display IC failing the SMC/TrueTone verification, which led to repeated reboots. I resolved the problem by visiting a third-party repair shop, where they installed an original LCD taken from an iCloud-locked iPhone. This display contains authentic Apple IC data and is properly recognized by the system.
Indice 0
1 commentaire:
I disagree with your analysis of the original poster's problem. The aftermarket industry has been making screens for years now, and they have figured out how to make them compatible with iPhones, with the exception that they can't be paired, and thus you cannot eliminate the genuine parts message with a non-OEM screen.
Basically it sounds like you got a bad screen which you could have worked around by either getting a warranty replacement or trying another vendor.
But yes, a genuine screen will work 100% correctly and now that the Repair Assistant is available all functions can be restored with an OEM screen.
par Partager
Ajouter une réponse
Phillip A sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 69
30 derniers jours : 284
Total : 3,315
