Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La troisième itération de la Galaxy Watch de Samsung avec un nouveau capteur BioActive et un design classique. Commercialisée le 27 août 2021. Modèle SM-R895F, 46 mm, version LTE.
New and old batteries both refuse to charge
I purchased a new battery from Ifixit for my Galaxy Watch 4 Classic. I followed the installation guide very carefully (Changement batterie Samsung Galaxy Watch4 Classic) and had no issues.
At first it worked fine: I charged it up, ran it down completely as instructed, and then went to charge it. The watch would charge for a few seconds or minutes, maybe showing 0% to 3%, then stop. If I tried again (and again) I'd get the same results.
Finally I gave up, assuming the battery was faulty, and put the old battery back in. It had about 14% power but immediately ran down to nothing and the watch shut down. It's refusing to charge again.
What am I missing? Could there be a bad connection to the battery somehow? Damage to some other part of the watch?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
have you checked the charging port? I messed mine up when I changed my galaxy watch battery
Indice 0
3 commentaires:
Thanks, but it charges wirelessly. There is no port!
par
@brad3488 as in that wireless connector, check if it works on another galaxy watch
par
Ahh, I understand! OK, I opened it up again, cleaned all the contacts between the battery, charger, and motherboard, raised the springy contacts a bit, and closed it again. It seems to be working now! Thank you so much!!
par
Ajouter une réponse
Brad sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 38
Total : 550
