Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation et le diagnostic de la batterie externe multifonction FixHub, principale source d'alimentation et interface de commande de la gamme de produits FixHub d'iFixit. Commercialisée en octobre 2024.
Temperature will not go above 200 degrees C
Just Purchased my Fixhub portable power station, when attempting the first use, I turned the knob to adjust the temperature, It was able to decrease the set temp down to 200 degrees, but when turning the knob to the right it does nothing, just stays at 200. It came with installed firmware version 1.3.0, and I did try to downgrade a version just to test with no luck. When pressing the knob to change the temperature units, the cursor would not move down to Fahrenheit. If I am missing the correct way to adjust temperature or if there could be something defective about my unit i would appreciate answers.
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
was this solved? I am having the same problem with mine. Never got use it. out of the box would allow for adjustment of temperatures.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
That is a strange situation! It sounds like the clockwise sensor on your Power Station control knob isn't working. I think a replacement of the UI Board should resolve the problem, please reach out to support@ifixit.com, and they'll take care of you right away.
Indice 2
Ajouter une réponse
Andrew Zywicki sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 12
Total : 137
