Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La manette sans fil Sony DualSense Edge (CFI-ZCP1) est sortie en janvier 2023. Elle est dotée de modules de joystick remplaçables et d'autres améliorations par rapport à la DualSense.
change joystick to tmr, but stick drifting
ive changed the joystick/analogy stick to tmr sticks in the dual sense edge, but the right one moves by itself to the left
Attach screenshot of the calibration screen, the left one calibrated fine but some reason the right stick does this drift to the left. Id appreciate if anyone can help or guide on the issue thank you
Répondre à cette question J'ai le même problème
Indice 3
3 commentaires:
Similar problem, installed Genfull sticks, the right stick does not work at all, and the calibration is the same picture.
Have you solved your problem? If so, how?
par
Did you remove the write protection on the stick module after replacing the stick? You need to either move some resistor positions or install a jumper wire.
par
Little blob of solder to jump it works too, also need to remove the 4.7k resistor to pin 3 as well. Cleanest way is to get a 100r in the empty spot and removing the 4.7k resistor.
par
Ajouter un commentaire
2 Réponses
Have you taken it apart again? In my case I could have put it in with the wrong screws or something easy like that.
Indice 0
3 commentaires:
yes only one screw in it
par
I’m having stick drift also. Tried recalibrating, then went back in and re flowed solder. No help. May remove totally the replace
par
Same issue, i tried 3 gulikit sticks. The third one lasted about two hours then hard left.the 4th stick is good calibration is still good.
Going to try hallpi sticks next.
par
The Memory chip has write protection. Little blob of solder to jump the empty pads to pin 3 of the memory chip works too, also need to remove the 4.7k resistor to pin 3 as well. Cleanest way is to get a 100r in the empty spot and removing the 4.7k resistor.
Watch this video for further explanation https://youtu.be/qKgAkAAnykg?si=rE8a8_r3...
Indice 0
Ajouter une réponse
matt91 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 36
30 derniers jours : 168
Total : 2,758
