Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation et informations pour le smartphone Xiaomi Redmi Note 7 Pro.
Phone not charging properly
Only charging when kept in a certain angle
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @isaacnewto53724
Use a strong light and a magnifying glass to check if there's any lint etc in the charge port enclosure that may be causing a poor electrical connection between the charger and the port.
If there is any there, do not use a metal pin or probe to try and clear it out as using it may damage the pins or cause electrical problems in the phone. Try using a vacuum cleaner to see if it can remove it.
If the port seems clear it may be a loose USB-C connector. If it is, it may be easier to replace the charge port board, rather than trying to resolder all the pins of a USB-C connector back onto the charge port board.
Here's a video that shows how to replace the charge port board in the phone.
Search online for Xiaomi Redmi Note 7 Pro charge port board to find suppliers that suit you best (examples only).
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
Indice 1
Ajouter une réponse
Isaac Newton sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 24
Total : 294
