Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le smartphone haut de gamme Apple de l'année 2020. Annoncé le 13 octobre et commercialisé le 13 novembre, l'iPhone 12 Pro Max inclut un écran OLED 6,7", une triple caméra arrière avec LiDAR et la connectivité 5G. Successeur de l'iPhone 11 Pro Max.
Is it save to solder the cell only iPhones battery to the BMS board?
dear All,
I wanted to replace my 12 Pro Max battery and intended to buy the cell only battery, without BMS board
Is it save to use nickel sheet solder wire, to solder battery tabs to BMS board? it tooks about 7 seconds to solder it with flux to the nickel sheet on BMS.
I have friends doing this, its more practical then using the spot welding tools?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi Aaron,
Spot welding is preferable, mainly for the reason that heat will quickly destroy a Li-Ion battery. Using a spot welder means there's a momentary intense flash of heat on a very small spot on the metal, while soldering means a much longer exposure time and wider area and thus more chance for the heat to transfer down the connections to the lithium itself.
That's not to say you can't do it with soldering, but you'll want to avoid getting the heat to the battery as much as possible. That means be very brief with the soldering iron, and solder as far away from the main part of the battery as possible. If you have some hemostats, you can clamp them between the solder point and the battery and they'll act as heat sinks to keep it from traveling down the metal strip.
Before I got my spot welder I did quite a bit of soldering directly on Ni-Cad batteries and so far I've had good luck with being quick and following the guidelines above.
Update (06/12/25)
@aaron75 I did realize which battery you were talking about, and I'm aware that the terminal strips should be made of zinc on the replacement cell. 5-7 seconds sounds long to me; I would use flux and quickly tin both leads first, then use the barest touch of the iron possible to get the BMS connected. Don't worry about it looking good or being smooth; you want a solid electrical connection in the very shortest amount of time possible.
Indice 1
1 commentaire:
oh sorry i forgot to mention the battery i'm talking abiut is iPhones battery, Lithium Ion Polymer
the + and - tab looks like plastic sheet takes around 5 - 7 seconds until soder melt perfectly
par
Ajouter une réponse
Aaron sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 59
Total : 558
