Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation, le démontage et le diagnostic de la Xbox Series S, la nouvelle console de jeu numérique de Microsoft. La Xbox Series S est sortie en même temps que sa grande sœur plus puissante, la Xbox Series X, le 10 novembre 2020.
HDMi needs replaced and I have no clue how too
I got my Xbox s last August and it stopped working in December it would turn on and I could hear the Home Screen with headphones in my controller but I can’t get a picture I’ve bought new hdmi cables but it doesn’t fix it would I be better replacing the part myself or taking it for repair?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
So little update I plugged my Xbox in to see if the issue was still ongoing and it was outs of frustration I slapped the top of my Xbox and it started working again I think I might be repair god
par
Ajouter un commentaire
1 Réponse
Solution retenue
It depends on how comfortable you are with soldering and disassembly. If you feel like you can do it yourself, go ahead! If not, there are plenty of repair shop that would be happy to fix it for you. If you plan to do it yourself here is the guide and here is the part (Or this part) you will need.
You also might need soldering tools.
If the kit linked is missing something just comment with what it is and i'll add it.
Happy iFixing.
Image Replace a corroded, dirty, or damaged HDMI port for an Xbox Series S model 1883 14 digit serial number gaming console.
Produit
Microsoft Xbox Series S Model 1883 (14 digit serial number) HDMI Port - Genuine
$17.99
Indice 3
5 commentaires:
Thank you for the advice I do have a mini soldiering kit and micro tools but no kidding yesterday I plugged it in to see if the issue was still ongoing it was so I got mad and slapped the top casing on the Xbox and it started working again 😂😂
par
@kerr35832 Sometimes it just needs motivation. Glad it's working!
par
Could be a bad joint on the hdmi port connector on the board that needs reflowed and by banging it has knocked it back together. Whilst it's on, gently move the hdmi cable at the port. Don't go mad just tiny movements to see if the picture goes off again. The retimer chip could also be on its was out. Not something you could do at home unless you have a hot air station.
par
My gf damaged the hdmi entrance can I get info how to fix it
par
thats exactly same thing here
par
Ajouter une réponse
Kerr sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 21
7 derniers jours : 113
30 derniers jours : 561
Total : 5,519
