Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Windows 10 est une version majeure du système d'exploitation Windows. Elle est sortie en 2015.
File Explorer and Disk Management does not recognize my 2 USB drives.
One always has a flash drive in it and one gets an external drive. Both have been working fine, now neither of them show.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @arenard
Do other USB show as detected when they're plugged into the same USB ports on the computer?
If they also don't show, go to Device Manager → Universal Serial Bus controllers → select > to expand the list → right click on a USB Root Hub entry → Properties → Power management and see if the "Allow the computer to turn off this device to save power" check box has been selected.
If it has been selected, uncheck it → OK
Do the above for all the USB Root Hubs shown in the list.
When complete, close all open windows and the restart the computer in the normal manner.
Once it has restarted etc, insert a USB drive and check if it is being detected OK.
To get to Device Manager in Win10/11 press the Win key + x key (both together) and select the Device Manager link in the menu box that opens.
Indice 2
2 commentaires:
I flip flop them and it makes no difference. I inserted a different flash drive that I haven't used for awhile and that doesn't show either. I will follow your directions and let you know.
par
You are wonderful. I followed your directions and both are working now.
par
Ajouter une réponse
arenard sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 25
Total : 261
