Le Lenovo IdeaPad Gaming 3 15IMH05 est présenté comme un ordinateur portable de jeu abordable, conçu pour offrir une expérience de jeu fiable. Cette page fournit des tutoriels de réparation pour le modèle 81Y4 de cet ordinateur et répond à certaines questions de diagnostic.
Some of my keys on my keyboard are not working. Keys like the T,A,Y,C and number 3 do not respond however you can push it and veel it go down slightly just like pressing any op the other keys. What should or can I do to repair it? What could be the cause?
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
If it has gotten wet or even if it hasn't then it could be a faulty keyboard matrix, but in trying to fix a keyboard you can create more problems than you originally had so it is easier to simply replace the keyboard.
To do this you would have to nearly completely disassemble the laptop.
Go to p.43 (49 of 60pdf) to view the procedure to remove the Remove the upper case (with keyboard and touchpad).
Lenovo doesn't supply the keyboard as a separate part. It comes as a complete module with the upper case assembly. You will have to remove the touchpad from your laptop and insert it the new upper case assembly though as it isn't part of the module. You could try sourcing a compatible keyboard only, but this would involve either cutting off the nylon plugs that fix the keyboard to the assembly or drilling out the metal rivets that hold it on, (not sure which method is used in your model). Then you would have to somehow glue the new keyboard back in place.
Also there are 64 different keyboard upper case assemblies available for the laptop. They are country i.e. language, colour and backlit (Y/N) specific, as well. The easiest way to know which is the uppercase assembly for your particular model is to look for the part number located on the underside of the uppercase assembly e.g. 5CB0Z20927 (USA) , 5CB0Y99514 (GER) etc, and search online using the part number to find suppliers.
If it has gotten wet besides having to so the above, you would also have to check if the motherboard is OK and hasn't also been affected e.g. corrosion or other liquid damage
So Check you keyboard for all of the issue mention above, And also try to use a another keyboard and check does the issue exist, If yes the outdated or corrupted can be the main reason for this so updated your keyboard driver to it's latest version.
