Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tout sur la réparation iPhone 14 Plus. Ce nouveau format Apple pour la gamme 14 comprend un écran OLED de 6,7 pouces – comme le Pro Max – mais les mêmes caractéristiques que l'iPhone 14 avec une configuration à double caméra et la puce Bionic A15 au processeur graphique à 5 cœurs.
Can we install iPhone 15 plus vibrator / Taptic Engine with 14 plus
Can we install iPhone 15 plus vibrator / Taptic Engine with 14 plus Will it work
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
iPhone 15 Plus
The Taptic Engine cannot be installed on the iPhone 14 Plus. This is because it is a dedicated part for each model and is not physically and electronically compatible.
Reasons for incompatibility
Dedicated design: The internal components of the iPhone, including the Taptic Engine, are designed for specific models and are not compatible with other models.
Physical differences: Although the dimensions of the iPhone 14 Plus and the iPhone 15 Plus are very similar, there are slight differences in the placement and size of internal components. This also affects the physical shape and installation position of the Taptic Engine.
Differences between connectors and electronic circuits: There are several design changes between the two models, such as the Lightning connector for the iPhone 14 Plus and the USB-C connector for the iPhone 15 Plus. These differences also affect the compatibility of flexible cables and electronic circuits that connect the Taptic Engine.
Possibility of feature limitations: Even if it is physically installed, using non-Apple genuine parts or parts from different models will not only not work as intended, but also will prompt an error message or restrict some features. There is a possibility that it will be
In conclusion, if a repair or replacement is required, you must use a Taptic Engine replacement part dedicated to the iPhone 14 Plus.
Indice 0
Ajouter une réponse
Manas Kumar Tarei sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 111
