MacBook Pro 14″ (M4, 2024) boots on battery but shuts down on charger
Model & history
MacBook Pro 14″, late 2024 (M4, base model)
  • Tea spill on keyboard ~4 months ago. Local shop did a cleaning - no parts replaced. Machine has worked perfectly since.
  • Battery still healthy; macOS Sequoia.
Current symptoms:
  1. If I power up on battery alone, the Mac runs normally (until it dies from low battery).
  2. As it's low battery, when I power up I get a message that displays the "runs on reserve battery life" and the macOS first shows the yellow-triangle “The version of macOS on the selected disk needs to be re-installed” screen. When I click Recovery → Reboot the macOS from Recovery, the Mac runs normally .
  3. The moment I attach any external power—Apple 140 W brick + MagSafe 3, or known-good 96 W brick over USB-C, or USB-C on the opposite side—the MagSafe LED blinks amber for ≈1 s and the whole laptop shuts off. Same behaviour on both USB-C ports.
  4. Reconnecting the charger while the Mac is off causes a brief blink, then nothing. Unplugging the charger lets me boot again on remaining battery.
  5. Tried three different chargers and two MagSafe 3 cables; cleaned all ports with 99 % IPA; let it dry 24 h—no change.
What I’ve ruled out / measured:
  • Charger and cable (swapped).
  • MagSafe DC-in board (visual inspection—looks clean, no charred pins).
  • Battery fuse appears intact (machine boots on battery).
  • Liquid-detection lock doesn’t match the hard power-off I’m seeing.
Suspicions from research:
  • Faulty RAA489900/RAA489901 charger IC (U7200) or shorted PPBUS bulk cap.
  • Less likely but possible: both CD3219/3220 USB-C PD controllers or the ideal-diode MOSFET pair.
  • Repeated hard shut-offs are probably what corrupted the Signed System Volume and trigger the yellow-triangle screen.
Goal:
Figure out the issue and whether a U7200 re-chip (or cap swap) is worth attempting if that's the cause.
Thanks in advance for any schematics, voltage points, or hard-earned wisdom you can share!
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
I haven't found any free copies of the schematics and board view drawings. Given the tea spill I suspect there was still some left on the board which wicked its self under a component or two creating a fault's signal via corrosion. Clearly its part to the power switch logic which will need deep investigation.
par
Ajouter un commentaire
