Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations et tutoriels de réparation pour déshumidificateur, un appareil qui élimine l'humidité de l'air de votre maison.
Help finding a compatible capacitor for GE Hisense DH70KP1WG
Need a new capacitor, and cannot find CBB65 50uF +5% 250VAC anywhere. I can find with a different uF or +6% or higher VAC. Specifically, the closest I have found is 50 uF ±5% 50 MFD 370/450 V CBB65. Should this work, or not?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi @cz12337240
It is OK to use a capacitor having the same capacitance value and a higher voltage rating than the original.
Never use a capacitor with the same capacitance and a lower voltage rating than the original as most likely it will damage the capacitor and possibly other components as well.
Indice 2
COCAPCO CBB65 250VAC 50uF Run Capacitor 50MFD 50 uF MFD 250V AC SH B.P2/S2 50x76mm 40/70/21 UL Listed: Amazon.com: Industrial & Scientific
I'm seeing several on Amazon that meet your specifications. The only other consideration would be the package size; you may have to measure the height and diameter to ensure it fits, but if there's room for it, this one would work. A general search for "CBB65 50uF +5% 250VAC" shows me several results.
Indice 1
Ajouter une réponse
CZ123 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 14
Total : 237
