Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le HP ProBook 640 G1 est un ordinateur portable sorti en 2014. Il est équipé de processeurs Intel Core de 4e génération, d'un écran 14 pouces antireflet, ainsi que de diverses options de sécurité et de connectivité.
On pressing power button lights blinking unlimited times , not on lapt
On pressing power button my laptop power button and other wifi and speaker + chargin lights keeps on blinkg , but laptop is not turning on I have tried all possible methods, removed RAM , SSD, Pressed power button for 60 seconds, then plugged in power and turned on but nothing working, tried to flash new bios using usb , it is also not working
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Réponse la plus utile
If your HP ProBook 640 G1 blinks its power/Wi-Fi/speaker/charging LEDs continuously but won’t turn on, and you’ve already tried:
  • Removing RAM & SSD
  • Holding the power button (discharge)
  • Flashing BIOS via USB
…then this sounds like a hardware-level failure. Let’s break this down properly so you can confirm what's going wrong:
🔦 LED Blinking Pattern = Error Code
HP laptops use LED blink codes to show hardware issues.
  1. Count the number of blinks (power LED or caps lock/wifi light often blinks a pattern: e.g., 3 blinks, pause, 3 blinks).
  2. This pattern tells you which component is failing:
  3. of Blinks Error Meaning 1 blink CPU failure 2 blinks BIOS corruption 3 blinks Memory/RAM error 4 blinks Graphics controller 5 blinks System board (general) 6 blinks BIOS authentication
❗If it's blinking non-stop without a pause, that's often motherboard failure or short circuit (no specific code = severe issue).
🧪 Steps to Further Troubleshoot
1. Check Power Adapter & Battery
  • Try powering on with battery removed, AC adapter only.
  • Try a different adapter if possible. A faulty adapter can cause this behavior.
2. Minimum Boot Test (Bare Bones Boot)
Do this on a non-metal surface:
  • Remove battery
  • Remove SSD/HDD
  • Remove RAM sticks (both)
  • Disconnect CMOS battery (if possible, for 2+ minutes)
  • Hold power button 60 seconds
  • Plug in only power adapter
  • Power on
🟡 With no RAM installed, the laptop should blink 3 times to show “RAM missing.”
→ If it does not do that → motherboard or CPU failure is likely.
3. BIOS Crisis Recovery Attempt (last chance)
If BIOS is corrupted, the laptop may not post, but you can attempt BIOS recovery from USB:
  1. Go to HP’s site → Support page for 640 G1
  2. Download the BIOS .exe file → extract it on another working Windows PC
  3. Copy BIN or ROM file to a USB drive formatted in FAT32
  4. Plug it into the laptop's USB port
  5. Press and hold Win + B or Win + V, then press power button
  6. Keep holding the keys for ~30 sec
🟢 If BIOS recovery is supported, the laptop may beep and read the USB → flash new BIOS.
⚠️ Doesn’t work on all models. If no reaction, this confirms severe hardware-level problem.
🛠️ Final Diagnosis Summary
Condition Likely Issue LED blinks in infinite loop Motherboard fault or BIOS corrupt beyond recovery No POST, no beeps, no fan Dead CPU / severe mobo failure No RAM = no 3 blinks Mobo not even initializing POST BIOS flash via USB fails BIOS chip failure / southbridge problem
🧯 What You Can Do:
🔧 Repair Path:
  • Replace motherboard (~$50–$100 used/refurb on eBay)
  • If you're experienced, inspect board for burnt areas or swollen capacitors
💰 Alternative:
  • Sell for parts (RAM, screen, keyboard, etc. are still valuable)
  • Consider replacement; this model is nearly a decade old (2013–2014)
If you want help finding a replacement motherboard or part number, just tell me your CPU (i5 or i7?) and I’ll get you a direct link.
Indice 1
Ajouter une réponse
Musharaf Ali sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 45
Total : 846
