4ème génération de l'Apple iPhone. La réparation est relativement simple, mais la vitre avant et le LCD doivent être remplacés ensemble. GSM / capacité de 8, 16 ou 32 Go / Modèle A1332 / noir et blanc.
Questions au sujet de 3260 Voir tout
Plugged In, But not holding a charge.
Okay, so my iPhone is plugged in, and it has a symbol on the battery, and the symbol is the plug, NOT the light bolt which indicates it's charging. So long story short, I want to know if my battery is damaged, like how could I tell?
I have a custom back on, and I think that's when I damaged it. Just to be safe, I have a new battery on the way.
OTHER INFO: The phone flashes off and on over and over again, it stays on about 2-5 minutes, and then flashes. It gives me time to do small things, like send a text, but even then it isn't really charging.
I would just like some help, I don't have a back up phone, and I can't afford to replace the whole phone from apple.
Is anyone else experiencing these problems as well? Just shed some light on this subject for me.
ALSO, I am going to leave it plugged in to see if over night it'll fix it's self. The battery looked kind of fried when I took it out, in the back it had a weird look, like an acid look to it. So maybe I discovered a problem early before it got worse.
Last but not least the side next to the dock connector, it looks like there's a dent there. Like a bad one, but at least the phone turns itself on. Did a clean restore twice so bare with me.
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Isiah Strange, I would start with a new battery and see what happens. Should that one not charge as well, replace the dock connector and see what happens. The instructions for that are here Hope this helps, good luck.
Cette réponse est utile ?
Score 1
Ajoutez une réponse
Isiah Strange sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,712
