Swapped with Mid 2009 Display/Sleep Sensor
I have the late 2008 early 2009 MBP Unibody 15" with the removable battery.
I recently swapped out the LCD assembly with the mid 2009 LCD assembly.
I later discovered that the mid 2009 LCD has the sleep sensor magnet on the left side of the screen rather than on the right side.
I want to avoid peeling the glass display off and moving the magnet to the other side.
My question is, is there a way where I can re-route the sleep sensor, located on the right side, to the left side where the USB/Mini Display connections are at?
1 commentaire
I checked it out and there isn't enough of the wire strip to be routed to the otherside; on top of that it's linked to the infrared.
Do you know if the the mid 2009 sensor will work with this series and how would I go about in rigging it?
par linuxduckie
