Aller au contenu principal
Pour réparer ensemble - Je crée un compte
A1418 / EMC 3069 / 2017 / Processeur quadricoeur i5 à 3,0 GHz, quadricoeur i5 à 3,4 GHz ou quadricoeur i7 de 3,6GHz. Sorti le 8 Juin 2017.
Very slow writing speed
Since the SSD upgrade, the writing speeds on my iMac are extremely slow. Is this due to a faulty Hard drive?
Update (08/08/25)
Répondre à cette question J'ai le même problème
Indice 1
2 commentaires:
If you had a Fusion Drive system (HDD & SSD fused into being seen as one drive but are still two physical drives)
And you replaced either of the drives then the system can run dog slow as the surviving drive of the Fusion set is trying to access its mate drive which is now gone.
The Drives configuration and its setup would need to be understood to fix this.
par
Thanks! I'll post a pic of the drives
par
Ajouter un commentaire
1 Réponse
@felixfleck - Well yes indeed this is a Fusion Drived system and the Blade SSD 28GB is slowing down your replacement SATA SSD (500GB) for the HDD it once had. You'll need to remove it following this guide Changement SSD blade iMac Intel 21,5" Retina 4K (2017)
Indice 0
Ajouter une réponse
Felix Fleck sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 154
