Aller au contenu principal
Pour réparer ensemble - Je crée un compte
1987 Honda Elite CH150 scooter. Some call it the Honda spacey.
Why is it that my engine is hard to start and when it starts it cut ou
Why is it that my engine is hard to start and when it starts it cut out when high gears are engaged or when climbing a hill
Répondre à cette question J'ai le même problème
Indice 3
1 commentaire
I need more information to answer.
par
Ajouter un commentaire
4 Réponses
Réponse la plus utile
Carburador da moto
Indice 2
Como botar um farol
Indice 0
if it idles ok it is not the air leak it is more likely the float level cutting off to early had same issue sputters acts like spark plug it is carb if jets arew clean check manifold for leaks if no power check your clutch belt too. also the elits have a over flow tube from carb that will evaporate the gas in carb if sittiing more than 3 days people are putting fuel filter on extra causing less gas to carb make sure tank isn't to rusty will be cleaning carb slow jets alot. don't run a hot or cold plus like in the snow weather will caucing rich issues
Indice 0
My bike Has No Any signal in the display and not start and not coming current
Indice 0
Ajouter une réponse
Christopher Bryan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 120
Total : 877
