Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP PROBOOK 6560B | The battery got slotted weirdly after a short fall
The battery on my HP Probook 6560b got slotted weirdly after a quick fall , nothing is broken but the weird slotting is stopping the battery connectors connecting to the Laptop
Yeah i forced the release to get it back in place and ripped it but i can always re latch it in when i un screw the computer , As the battery is stuck i can't remove it , i can't remove the back edge cover too because there's screw under the battery slot that i can't access
If the photo is not clear , basically the left latch is latched in correctly but the right one is not latched in and it won't latch because it's under stress
i have a theory to fix but i don't know about the result is to like try to push the right latch tr in place by prying the battery out and using a screwdriver to slot the latch in the release position to hopefully install the battery correctly then i will remove it via using the release as it will work then unscrew then re latch the release button
Any questions or answers are welcome , and thank you in advance for this
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
I have had to do this on a Compaq CQ56 and a HP G60-230US before, and this works BUT don't pry too hard or you risk damaging the battery shell. What you need to do is hold the latch in the release position and insert something into the dislodged side. It does require some practice to get right, but once you get it in place, then you are good to get it out. Once it's removed, just slot it in normally as if it never happened.
Back when I had to do it on those machines, I used a butter knife and frankly that works VERY well but it needs some caution around the terminal block. If you can use a spudger, that's far safer but could take more time.
Indice 3
7 commentaires:
also any way to put the release latch back in bc it got removed too and won't click in because the hook it clicks in is on a spring
par
@teomanoff you will need to snap that back in by pushing down on it. Happens a lot on that design.
par
so with the disloged side i push the clip to the release positon or do i pry the battery out
par
@teomanoff you need to pry there.
par
@nick so i just force battery out like a monster with the release pulled ?
par
Voir 2 commentaires en plus
You really gonna need to force it out while being careful of breaking it and after make sure you have a new battery as a replacement
Indice 1
1 commentaire:
ima try to do it without breaking
par
Ajouter une réponse
TeomanOFF sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 24
Total : 296
