Aller au contenu principal
Pour réparer ensemble - Je crée un compte
My laptop won't charge
I have two HP laptops. One of them won't charge using the same charger. If I charge the battery on the first one and place it in the second laptop work fine. I disassembled it and checked for the DC power jack, and it worked perfectly. Any ideas about what could be the problem?
Répondre à cette question J'ai le même problème
Indice 0
4 commentaires
Have you tested that the battery of the non-charging laptop works? If not, try putting that battery in the laptop that won't charge and see if you get the same issue.
par
@havynkrentz battery works perfectly. I guess there's some problem in the motherboard. Everything works as it should, except it won't charge.
par
@anwar29099
What is the full model number of the laptop that doesn't charge?
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @anwar29099
Here are the motherboard schematics that should help.
Go to p.8 and following the DCIN path from pin 1 of the DC-IN cable connector on the motherboard to see how far you get. Also check that the circuits connected to the other pins i.e. 3,4 &5 are also OK
Indice 1
Ajouter une réponse
Anwar sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 141
