Comment renouveler les bougies d'allumage de la 207 essence 1.4
Comment changer les bougies d'allumage de la 207 essence 1.4
@hakoo49826 first, you're going to want to make sure the engine is completely cooled down. Next open the hood and remove the engine cover. You'll see the coil packs now, and you'll want to carefully disconnect the electrical connectors and hoses attached to them before removing the packs.
Now, here's a crucial step: when you get to the spark plugs, use a 14mm socket with an extension. As you unscrew the old ones, just keep in mind that you're going to replace them one at a time. This will help you keep things organized and prevent any mix-ups. The most important thing is to install the new plugs by hand first. Just screw them in gently until they're snug. This will help you avoid cross-threading and other damage to the engine. Once they're in, you can use your socket to carefully tighten them.
After that, just reverse your steps—reinstall the coil packs, reconnect everything, and put the engine cover back on.
Of course, you can also use something like this video
For the exact model of sparkplugs to be used, we will need to know the exact year of your Peugeot.
While you work on your car, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@hakoo49826, d'abord, assure-toi que le moteur est complètement refroidi. Ensuite, ouvre le capot et enlève le cache-moteur. Tu verras alors les bobines. Débranche soigneusement les connecteurs électriques et les tuyaux qui y sont reliés avant de retirer les bobines.
Maintenant, voici une étape cruciale : lorsque tu arrives aux bougies, utilise une douille de 14 mm avec une rallonge. Quand tu dévisses les anciennes, pense à les remplacer une par une. Ça t'aidera à rester organisé et à éviter toute confusion. Le plus important, c'est d'installer les nouvelles bougies à la main d'abord. Visse-les doucement jusqu'à ce qu'elles soient bien serrées. Ça t'évitera de fausser le filetage et d'endommager le moteur. Une fois qu'elles sont en place, tu peux utiliser ta douille pour les serrer avec précaution.
Ensuite, refais tout dans l'ordre inverse : remets les bobines, rebranche tout et remets le capot du moteur.
Bien sûr, tu peux aussi utiliser quelque chose comme cette vidéo
Pour connaître le modèle exact des bougies à utiliser, on aura besoin de l'année exacte de ta Peugeot.
Pendant que tu travailles sur ta voiture, prends plein de photos. Une fois que t'as fini, prends ces photos et crée un guide pour iFixit. Ça aidera la prochaine personne qui aura un appareil avec les mêmes problèmes que toi. C'est facile et amusant de créer ces guides. https://fr.ifixit.com/Guide/new La communauté iFixit t'en sera reconnaissante.
Réparer, c'est la guerre contre l'entropie !
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 20
Total : 342
@hakoo49826 what is the exact year for your Peugeot?
par oldturkey03 Partager
لدي مشكل في حساس الاكسجين
par Mahamedi Mohamed Partager
@mahamedimohamed what kind of problem? what exact year is your Peugeot 207 and what have you already tried?
@mahamedimohamed C'est quel genre de problème ? De quelle année est ta Peugeot 207 exactement, et qu'est-ce que t'as déjà essayé ?
@mahamedimohamed ما نوع المشكلة؟ ما هو العام بالضبط الذي صُنعت فيه سيارتك «بيجو 207»؟ وما الذي جربته حتى الآن؟
