Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Samsung Galaxy A23 a été lancé le 6 mars 2022. Il est identifié par le numéro de modèle SM-A235F.
My phone is not connecting to charger
My phone is not charging
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@tamimsafai could be a bad battery, bad charging circuit or a bad charging port. The easiest is to actually replace the charging board. It is relatively inexpensive and replacing it is fairly straightforward. Also, check the flex cable from the charging board (sub_board) to the main board for any tears, corrosion etc. Once you have the board replaced, I would also replace the battery, since you have the phone open. That way you only have to do that one time.
Since iFixit does not yet have a guide for that, use something like this video to replace the parts.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War one Entropy
Indice 1
Ajouter une réponse
Tamim Safai sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 19
Total : 246
