Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Documentation de réparation pour la manette Sony PlayStation 5 DualSense de troisième génération. Numéro de modèle : CFI-ZCT1W ID FCC : AK8CFIZCT1A Carte mère : BDM-030
Audio jack not working
The audio jack was working fine until yesterday but today when fired up my console my wired JBL headphones wont connect. I tried with other controller and they seemed to work fine so not a headphone issue definitely a controller one... anyone know how to fix this?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
3 commentaires
Hi Sam!
Is the Dualsense it's firmware up to date? Just in case!
Do you use the controller on the PS5 or PC?
Do other headsets work or airpods or whatever?
Thanks!
par
I use it with ps5 and yeah firmware is up to date👍
par
Okay! That’s good! Do you have any other headset to test?? This would be the ultimate test.
In the worst case, you do need to replace the headphone jack.. this requires soldering and soldering experience!
par
Ajouter un commentaire
1 Réponse
Solution retenue
Hey,
This is a common issue with PS5 controllers, I've attached a YouTube link for a couple quick diagnosis methods. Unfortunately if none of these methods get your controllers audio jack working again you may have to replace the audio jack which will require you to disassemble the controller and do some soldering.
Here is the YouTube link.
https://youtu.be/0goVWJZ_Ozo?si=A6N_OHSO...
Hopefully this helps, best of luck!
Indice 1
3 commentaires:
Thanks so much man cleaned it with alcohol issue resolved 👍👍
par
All good, glad you got it sorted.
par
Glad that it is working! Have fun gaming again!
par
Ajouter une réponse
Sam Medadkar sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 99
30 derniers jours : 447
Total : 3,485
