Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La PlayStation 3 Slim est la deuxième version de la console de jeu vidéo PS3 produite par Sony Computer Entertainment. Elle est sortie le 1er septembre 2009.
Si j’allume ma ps3 slim elle s’allume et fait deux bips et s’éteint
Répondre à cette question J'ai le même problème
Indice 3
1 commentaire
@mohamadouh95605 lets see if our game console guru @dan0 has a solution for you.
Translation
@mohamadouh95605, voyons si notre expert en consoles de jeux @dan0 a une solution pour toi.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi!
This could be caused by the YLOD or overheating.
First, I would remove all the dust and replace the thermal paste and see what happens.
Guide: PlayStation 3 Slim Thermal Paste Replacement - iFixit Repair Guide
If it's still failing, then the CPU/CPU need to be fixed. It probably do have colt solder joints causing the issue.
In this case you have a few things that you can do:
1: A reflow. This is the most inexpensive fix, but is most of the time temporary... You can try it to see if it works afterwards.
2: Reballing! This is the fix you want, but also the most difficult one to perform. This will fix the issue for good, but requires BGA solder work. So you need a lot of experience and expensive devices to get this done... Most likely you want to contact a local repair shop to let them do it for you.
3: Replacing the motherboard! The most easy fix, but also the most expensive one. It's also hard to find a good motherboard online.
To give you a idea about the reflow: Yellow Light of Death Repair - iFixit Repair Guide (I know that this is meant for the PS3 phat, but just to give you an idea)
Please let me know how it goes!
Translation:
Bonjour !
Cela pourrait être dû à un YLOD ou à une surchauffe.
Tout d'abord, je vous conseille de retirer toute la poussière, de remplacer la pâte thermique et de voir ce qui se passe.
Guide : PlayStation 3 Slim Thermal Paste Replacement - iFixit Repair Guide
Si le problème persiste, il faut alors réparer le processeur. Il y a probablement des soudures Colt à l'origine du problème.
Dans ce cas, plusieurs solutions s'offrent à vous :
1 : Refusion. C'est la solution la moins coûteuse, mais elle est généralement temporaire… Vous pouvez essayer pour voir si cela fonctionne par la suite.
2 : Rebillage ! C'est la solution idéale, mais aussi la plus difficile à réaliser. Elle résoudra le problème définitivement, mais nécessite des soudures BGA. Il faut donc beaucoup d'expérience et des appareils coûteux pour y parvenir… Il est préférable de contacter un réparateur local pour qu'il le fasse pour vous.
3 : Remplacement de la carte mère ! La solution la plus simple, mais aussi la plus coûteuse. Il est également difficile de trouver une bonne carte mère en ligne.
Pour vous donner une idée du reflow : Yellow Light of Death Repair - iFixit Repair Guide (je sais que c'est destiné à la PS3, mais c'est juste pour vous donner une idée).
N'hésitez pas à me faire part de vos impressions !
Image PlayStation 3 Lumière jaune de la mort (YLOD)
Tutoriel
Difficulté :
Difficile
1 - 2 hours
Image PlayStation 3 Slim Pâte thermique
Tutoriel
Remplacement de la pâte thermique de la PlayStation 3 Slim
Difficulté :
Modérée
1 - 2 hours
Indice 1
Ajouter une réponse
Mohamadou Hamidou sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 55
Total : 308
