Pourquoi mon écran s allume en noir?
Pourquoi mon écran s allume en noir ?
@dweezy you are not telling us when it turns black. It is possible that this is caused by a bad backlight. Try this: darken the room and turn the computer on. Then use a flashlight and angle the light at the screen on different areas. If you make out shapes or even see your desktop, you know it is you backlight. If you can't see anything, then it can be your motherboard.
Next connect an external monitor to your computer and see if that displays correctly. If it does, you know it is your LCD. If it does not, the issue will be with the GPU on your motherboard.
If you can't see anything, then it can be your motherboard. Even a backlight issue could still come from the motherboard. You would need to measure the backlight voltages on your display connector.
To do a deep dive we will need to know the exact motherboard that your computer is using. For a check of the display adapter etc. we will need to find the schematic and you will need to have a multimeter that you can use to test a few things on your motherboard.
To work on your computer, use the HP 240 14 Inch G9 Maintennce And Service Guide Sorry, I only have an English version but it should still help you out as well. Remember, you can always post some pictures of where you might be stuck or where you might need some extra help. Just post those picture with your Question.
Translation
@dweezy, tu ne nous dis pas quand l'écran devient noir. C'est peut-être à cause d'un problème de rétroéclairage. Essaie ça : assombris la pièce et allume ton ordi. Ensuite, prends une lampe de poche et pointe la lumière vers l'écran à différents endroits. Si tu vois des formes ou même ton bureau, c'est que le problème vient du rétroéclairage. Si tu ne vois rien, c'est peut-être ta carte mère.
Ensuite, branche un écran externe à ton ordi et regarde si ça s'affiche correctement. Si c'est le cas, tu sais que c'est ton écran LCD. Si ce n'est pas le cas, le problème vient du GPU de ta carte mère.
Si tu ne vois rien, ça peut venir de ta carte mère. Même un problème de rétroéclairage peut venir de la carte mère. Tu devras mesurer les tensions du rétroéclairage sur le connecteur de ton écran.
Pour approfondir, on va devoir connaître le modèle exact de la carte mère de ton ordi. Pour vérifier la carte graphique, etc., on va devoir trouver le schéma et tu auras besoin d'un multimètre pour tester quelques éléments de ta carte mère.
Pour travailler sur ton ordi, utilise le HP 240 14 Inch G9 Maintennce And Service Guide. Désolé, je n'ai qu'une version en anglais, mais ça devrait quand même t'aider. N'oublie pas que tu peux toujours poster des photos des endroits où tu bloques ou où tu as besoin d'aide supplémentaire. Il suffit de poster ces photos avec ta question. https://fr.ifixit.com/Tutoriel/Ajout+d'i...
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 99
