Pourquoi mon redmi ne s'allume et ne ce charge 0as
Le téléphone ne veut pas charger et ne peut pas s'allumer
@aaron91019 it may not turn on right now since the battery may be depleted and/or the power no longer reaches your battery/main board. The very first thing I would suggest you try is to check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
My primary suspect on this, is actually the charging board. If this would be my phone, I would replace that board and the battery. Also, check the flex cable from the charging board to the main board. Make sure it is properly seated, has no corrosion or tears etc.. If in doubt, replace that as well.
Since iFixit does not yet have a guide for this phone, use something like this video You can see at the 3:00min mark how to remove the charging board. Replacements are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@aaron91019, il se peut que ton appareil ne s'allume pas pour l'instant parce que la batterie est à plat et/ou que le courant n'arrive plus jusqu'à ta batterie/carte mère. La première chose que je te conseille de faire, c'est de vérifier ton chargeur. Assure-toi qu'il a une bonne sortie. Vérifie ensuite ton câble de recharge. Vérifie que les connecteurs ne sont pas tordus, etc. Après ça, vérifie le port de charge. Nettoie-le pour enlever les débris, etc., en soufflant dessus plusieurs fois. Si ça ne marche pas, prends un ampèremètre USB et regarde si ton téléphone tire du courant du chargeur. Si ce n'est pas le cas, c'est peut-être un problème de port de charge ou une batterie défectueuse.
Je pense que le problème vient surtout de la carte de charge. Si c'était mon téléphone, je changerais cette carte et la batterie. Vérifie aussi le câble flexible qui relie la carte de charge à la carte mère. Assure-toi qu'il est bien branché, qu'il n'est pas abîmé ou corrodé, etc. Si tu as un doute, change-le aussi.
Comme iFixit n'a pas encore de guide pour ce téléphone, regarde plutôt cette vidéo. À 3 min, tu verras comment retirer la carte de charge. Tu peux facilement trouver des pièces de rechange dans plein de boutiques en ligne.
Pendant que tu travailles sur ton téléphone, prends plein de photos. Une fois que t'as fini, utilise ces photos pour créer un guide pour iFixit. Ça aidera la prochaine personne qui aura un appareil avec les mêmes problèmes que toi. C'est facile et sympa de créer ces guides. https://ifixit.com/Guide/new La communauté iFixit t'en sera reconnaissante.
Réparer, c'est lutter contre l'entropie !
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 83
Total : 764
