Aller au contenu principal
Pour réparer ensemble - Je crée un compte
In 1991 for the 1992 model year, Isuzu completely redesigned the Trooper to keep pace with changes in the SUV marketplace, making it larger, more powerful, and more luxurious.
The license plate assembly. What's it called?
Is my 1992 isuzu trooper LS a big horn or jackpot?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
License Plate Assembly Name
The part you're referring to is typically called the license plate lamp assembly or license plate light housing. It includes the bracket or frame that holds the plate, plus the lights that illuminate it. If you're replacing it, you might also see it listed as a license plate bracket, license plate frame, or body & lamp assembly – license plate depending on the catalog.
1992 Isuzu Trooper LS: Big Horn or Jackpot?
Your 1992 Isuzu Trooper LS is most likely neither Big Horn nor Jackpot—those names were used for Japanese domestic market (JDM) variants or special editions. In the U.S., the Trooper LS was a higher trim level featuring upgrades like:
  • DOHC 3.2L V6 engine with 190 hp
  • Optional four-wheel ABS
  • More upscale interior and features compared to the base S model
If your Trooper was imported from Japan, it might carry the Big Horn badge, which was a luxury-oriented version. Jackpot, on the other hand, was a rarer, more playful trim name used in some limited JDM runs—not typical for U.S. models.
Indice 0
Ajouter une réponse
david underwood sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 148
