iMac no longer boots after security update- Does not see internal SSD
MacOS chose to automatically update my system last night, and I woke up to a computer which wouldn't boot up. The system instantly shows the apple logo but will do nothing else. NVRAM reset works right away, but recovery mode (online) and booting from a USB key shortcuts need to be held for about 15 min before they're recognized and work.
When in disk utility on either option, it does not seem to see my SSD anymore. It shows a 2gb partition (recovery partition I believe), and then a 30gb partition which the first aid fails. It has a fairly new 500gb samsung SSD installed which has been working great before the update.
Any ideas before I open up this machine to try and test the drive? Extremely frustrating for an update to cause this. Thanks!
Update (09/15/25)
This was a fusion drive before I purchased it. The Fusion drive was swapped out for the SSD. Only other upgrade was a ram upgrade at the same time.
The computer is a Mid 2017 21.5" Imac. Thanks!
Update:
Removed the hidden original SSD, but still having the same issues. Only drive I can see is this one, which doesn't help me.
2 commentaires
Can you tell us the model as Apple has produced quite a very versions of this system.
Also was this a Fusion Drive model when you bought it? That important to know.
par DanJ
@danj See above, meant to reply to you.
par Saltshaker185
