Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair and service information related to the ResMed AirSense 10 CPAP machine. Also known as the ResMed Air10.
Why isn't my machine shutting off after I take off the mask + 5 second
It used to power off 5 seconds after I took the mask off. Now it stays on until I use the button on the top to shut it off. This action started happening about 2 weeks ago.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Maybe some sensor contacts is stuck or got dirty because of usage?
Indice 0
4 commentaires:
Or somewhere in settings interval is changed?
par
@kapitalizm Where are these sensors located so I can check? Or what settings would be involved? Where can I find them?
par
@lynneclark Repairing medical equipment, especially expensive ones like this is difficult, it depends on technology used in device that detects mask removal. It can be pressure sensor, which, for example, detects inactivity when the mask is removed and sends a signal to turn it off. Or some other unknown technologic trick. Maybe this function can be also disabled by program settings, IDK because I didn't have the device in place.
par
This can be altered in the machine settings. The manual mentions this but if your machine is supplied by your medical professional they will need to adjust this. If your machine has wireless connectivity the firmware can be updated by your supplier/manufacturer - I suggest contacting your supplier directly to see if either of the above applies.
par
If you have leak detection on that will disable it from shutting off when you take your mask off... Try that. Worked for me when I got my 2nds Resmed 10 ASV
Indice 0
Ajouter une réponse
Lynne Clark sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 19
30 derniers jours : 60
Total : 531
