How to fix AC. When I turn on the AC my car start to jack off
When the air-corn is turned on it's driving fine but when I click the AC button it start to jack when driving
Look at the AC compressor when you turn on the AC, you should see the clutch locking in place and the compressor spin, if the compressor does not spin the compressor is locked (broken) that puts a strain on the engine as it is trying to spin a no longer movable part. I am guessing your AC is not cooling at all, but if it is cooling very little check again the compressor, if it spins and the clutch kicks in and out serveral times (you will see and hear the click in and click out) it could mean you are low in refrigerant due to a leak. You can add refrigerant and it will be fixed temporarily, if the leak is very small it will work for a while before starts doing the same. You can trigger this lock in and out idling at 2500-3000 RPM, sometimes it is lacking refrigerant but not enough to trigger this behavior idling at low RPM.
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 50
Total : 455
4 commentaires
What year is your i10? Which engine does it have?
What exactly do you mean when you say your car "start to jack off"? Around here that's a euphemism for masturbation, so I doubt your car is doing that.
par Jerry Wheeler
@dadibrokeit it a Hyundai Grand I10 1.0 motion
par Lunga Dlamini
@lungadlamini what year and exactly what does it do when you turn you AC On? The term you‘ve used is very non-descript when referring to a vehicle.
par oldturkey03
@oldturkey03 My car runs normally when I just use the fan or the air circulation, but the moment I press the AC button to switch on the air conditioning compressor, the car starts jerking. So the issue only happens when the compressor kicks in, not when the blower or fan alone is running.
par Lunga Dlamini
