Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation et le démontage du smartphone Pixel 6 de Google, sorti en octobre 2021. Identifié par le numéro de modèle GB7N6 et G9S9B16.
Dropped phone doesn't turn on unless connected to USB
Hello,
Just dropped my phone on the floor, it went black and wasn't turning on. After I connected it to USB, Google logo appeared on the screen, blinked 3 times and it booted normally. The second I disconnect USB, it goes black and unresponsive again.
I assume there's no power output from the battery?
When the phone is on (with USB), I can see the battery charge and charging icon, so it's not completely disconnected.
1. Should I try to check the battery connection?
2. If connection looks good, does it make sense to try to replace the battery?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @jackjones43148
Best option is to open the phone and check if the battery flex cable is just loose/disconnected or if there's some other obvious damage.
Here's the ifixit Google Pixel 6 repair guide that will help.
Indice 2
1 commentaire:
thank you!
(comment too short)
par
Ajouter une réponse
jack jones sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 64
