Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La mise à jour de mars 2015 du MacBook Air 11" d'Apple est dotée de processeurs Intel Core i5 et i7 de cinquième génération, offrant ainsi une légère amélioration des performances et de l'autonomie de la batterie.
More trackpad issues- MacBook Air 2015
Hi, I posted here yesterday about the click on my trackpad failing and after I resolved that issue (so I thought) by adjusting the screw sitting beneath the trackpad & increasing the tension, most of the trackpad works properly aside from the bottom left third that doesn’t register any clicks. I feel like I’ve tried everything at this point aside from replacing the trackpad itself but I’m not even sure that’s the problem because it functions otherwise perfectly. Any advice would be appreciated
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
I think it boils down to some more fine adjustment and to carefully look at the cable to see if any of the thin traces are deformed but I think this is unlikely. Make sure the TP is centered with equal space around all of the edges as it is easy to install them and they are ever so slightly to the left or right which maybe the reason of the no click, other than that not much I can think of. If you do remove it again give it another good cleanup where the contact points are.
Indice 0
Ajouter une réponse
Jet S sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 156
