Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'ASUS Essentio est un PC tour fabriqué par ASUS, identifiable par le numéro de modèle CM6870. Sorti en 2012.
Asus CM6730 no display on first attemp after restart work good
Asus CM6870 no display on first attemp after restart work good.its happen on every time when i power on computer after some time..before it was happen to next day when i turn on my pc with no display but after restart from swtich work good.and then whole day work good.then same thing happen to next day but now it is happening on every time.when i power on after few hours it happen.on keyboard no light
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @itsme25541
Try a full power refresh and check if that resolves the problem.
Here’s the procedure:
  • Disconnect the power to the PSU and then open the case and remove the RTC coin cell battery from its holder on the motherboard
When the battery is out, check its voltage. If it is <2.5V DC or if the battery is >4-5 years old, replace it. The battery model number is stamped on the battery e.g. CR2032 etc.
  • Press and hold the Power On button for a full 30 seconds and then release it.
  • Reinsert the RTC coin cell battery, (+ve on top as marked on the battery), close the case, reconnect power to the PSU and try to start it.
If it starts, there may be a message about the date and time being incorrect. This is normal as the above procedure has reset the BIOS back to its factory defaults. Once the date and time have been adjusted, the message won't appear the next time the PC is started. Any user defined BIOS settings that have been altered by you to suit your particular operating requirements will need to be changed back also.
Indice 1
Ajouter une réponse
Its me sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 19
Total : 178
