Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation, le démontage et le diagnostic de la Steam Deck avec écran LCD, une console de jeux portable fabriquée par Valve, sortie le 25 février 2022. Elle porte le numéro de modèle 1010.
What is this missing component and its specs so I an replace it
I got my hands on a pre-owned Steam Deck, and it crashes, freezes, and is generally randomly unstable. To my knowledge, the only missing component is circled in the image. I think it's a capacitor, but I could be wrong. I'm trying to find the specs of it to replace it
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
that looks to me like a resistor. capacitors are orange and resistors are grey. if you look at it under a magnifying glass there should be 3 numbers on it. the first two numbers is your ohm value and the third number is the exponent (x10^x), i.e. '473' is 47 with 3 zeros so 47000Ω or 47kΩ. side note. if your last number is 0, it means there are NO zeros. 470 is 47Ω not 470Ω. its not really possible to get the size from a photo, you'll have to measure it with callipers if you have some with enough resolution
Indice 0
1 commentaire:
SMC do not have any markings imprinted. You need the component layout diagram or a donor board to measure the values.
par
Ajouter une réponse
TheKnightOfTime sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 118
