Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Why is my trackpad clicking at random?
My trackpad has been clicking at random lately. I am not sure if I need to replace the upper case or if it could be another issue that is effecting the trackpad. Any pressure put on the top case will cause a click which is very annoying. The button also seems to get stuck in the down position from time to time.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Commentaires:
Is your battery swelling or bulging if you look at it.
par
It is actually. Slightly bulging from the bottom.
par
Ajouter un commentaire
2 solutions
Solution retenue
Try taking the battery out and see if the problem persists. If it doesn't then you need a new battery. The battery you currently have in there is most likely swelling and applying pressure to the underside of the trackpad.
Hope this Helps
Cette réponse a-t-elle été utile ?
Indice 2
Commentaires:
That was it. I knew it was kinda bulging a bit but didn't put 1 and 1 together. Still under warrantee so new one on the way.
Thanks again.
par
If this answer solved your problem please accept it so other can learn from your issue. Thanks
par
Hi,
I changed my battery one year ago, after 4 years of good services on a MBP 15.
The new battery lasted 1 year, and now is swelling, while the hard drive I changed at the same time lasted only 2 months (now having 2 ssd's).
It might be the crash in a car while riding my bike. (you should have seen the car and the bike ;) ... the laptop got a nice dent on a corner, the optical drive died and the hard drive (not a ssd) died shortly afterwards.
Indice 0
Ajouter une réponse
Leroy sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 9
7 derniers jours : 30
30 derniers jours : 59
Total : 6,393
