Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Lenovo ThinkPad T14 Gen 2 est le deuxième modèle de la série ThinkPad T14, doté d'un écran de 14 pouces, d'un choix entre des processeurs Intel et AMD, ainsi que d'une carte graphique Nvidia en option. Il est sorti en 2019, avec un prix variant selon les modèles.
Where is the small magnet that tells the laptop to sleep located?
The small square magnet that sleeps the computer when the lid closes fell out when I had the back plate off and didnt see where it came from and cant see where it goes?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @harrisontafft
By back plate I assume you mean the laptop's base cover assembly and not the lid cover, is this correct?
If it is then the easiest way to find out where to locate the magnet is to slowly run a magnet around the bezel of the screen assembly and check when the screen turns off.
Once the screen turns off, the location of the magnet will be in the base cover position opposite to where the magnet is being held by you on the edger of the screen bezel, when the lid is in the closed position
If you meant the lid cover, run the magnet around the edge of the keyboard/top cover assembly and note the position of the magnet when the screen turns off. The magnet position will be in the screen cover opposite to where you're holding the magnet on the keyboard /top cover, when the lid is in the closed position .
Indice 1
1 commentaire:
@harrisontafft besides the aforementioned great steps to find the location, use the Lenovo ThinkPad T14 Gen2 P14s Gen2 Hardware Maintenance Manual and search for Hall sensor. It will show you the location of the sensor (It is near near the top of the display, in the lid). The magnet will be exactly opposite of the sensor.
par
Ajouter une réponse
Harrison Tafft sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 96
Total : 764
