Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation, manuels et aide au diagnostic pour le fer à souder électronique FixHub | Power Series. Sortie en octobre 2024.
Smart Soldering Iron doesn't heat up, blinks blue 3x when on.
I'm using the iFixit Smart Soldering Iron with an iFixit 65 watt fast charger. Plugging them on together causes the indicator LED to just keep flashing blue 3 times fast.
I just updated the firmware and reset settings on the web console.
I'm using the provided USB-c cable.
What am I doing wrong? Why doesn't the manual have the error codes for the LED indicator light in a troubleshooting section?
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
3 Réponses
Réponse la plus utile
Hi! I'm having the same issue - got the station as a christmas present and needed to use it now, but the soldering tip blinks blue and there is no possibility to start soldering. Tried both tips I have but the result is the same.. Please help ASAP - Thanks!
Indice 1
3 commentaires:
Get in contact with the iFixit support to get a replacement sent out, I am fairly certain it was the USB cable, try a different one
par
@cocco17, Sorry this is happening. Right now the best option is to contact our support team.
par
Thanks, support sent me a new iron and not everything is working again 😊👍🏻
par
Three blinking lights always means "error" on the soldering iron. Orange lights (regardless of blinking) always means that the iron thinks the tip temperature is at or above the set temperature (350C by default), and blue (regardless of blinking) means that the iron thinks the tip is below 45C.
The reason that the ring turns orange when the tip is removed is because the thermocouple gives the same voltage reading whether the tip is disconnected or ~600C. The tip being disconnected is also an error state, hence the continued blinking when the tip is removed, that's expected behavior, so we can safely ignore the "orange" part of the error diagnosis.
In your situation, we see a blinking blue light (cold measurement, error state), with the tip plugged in. This could mean that the iron has experienced a freefall event, but given your account of attempts at heating up the tip, that seems unlikely. What is more likely is that the iron senses that the temperature isn't moving fast enough for a given power supply, and it is throwing an error. Because you had an instance where the tip did start to heat up, it's sounds like there is a fault either on the board itself preventing power from getting to the tip, or the heater in the tip has failed. Reach out to support for a replacement and we'll get you soldering again soon.
Indice 1
You first want to plug in the charger into the AC outlet, then plug the FixHub station into the charger. Then you should be able to plug in the iron into the FixHub unit.
Indice 0
9 commentaires:
I am not using a FixHub. I am plugging the iron directly to the 65W USB charger. I'm sure the product page and the guide says it would work? "However, it also works just fine with any power source capable of delivering at least 20W via USB-C PD."
par
@ikolino - OK, then without the FixHub are you first plugging in the charger into the power (AC) then plugging the soldering iron into it alone?
par
Yes, that is correct. It will pulse blue slowly for a couple seconds, and then flash blue 3x.
par
@ikolino, before you started using the iron with the charger, did you make sure to update the iron to the latest firmware?
par
Yes, like stated on the original post. After the firmware update, it even heated up for a couple seconds! But reverted to 3x blue blinking. I've tried it on different firmware versions to be sure.
par
Voir 4 commentaires en plus
Ajouter une réponse
ikolino sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 35
Total : 328
