Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Introduite en 2016 lors du lancement de la Xbox One S, la manette Xbox One ajoute le support Bluetooth pour Windows 10. C'est la manette grand public actuellement vendue par Microsoft. Elle rectifie un nombre de défauts de conception des manettes modèles 1537/1697 et elle est beaucoup plus fiable.
Why is my Xbox controller double inputing in menus?
In the Xbox menus (system, not game), my controller will always double input using the sticks or d-pad. I move one, it moves two with two separate sounds. It doesn’t do this to other controllers on the same console
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi!
It’s recommended to open it up and clean both
Boards completely with isopropyl alchol.
Also clean the rubbers and the pads on the motherboard. If you have issues with the dpad,, there is a sticker on thr board with metal pieces. You can take it off and clean it under there, then put the sticker carefully on it again (make sure to align it correctly) if it’a failing, replace the sticker with a new one.
Please let us know how it goes!
Indice 1
2 commentaires:
But if it were something like residue that can be fixed by cleaning, why would it only happen in System Menus, and not in game menus?
par
Sorry, I assumed that it happened in the menu and in the games it self. Is the Xbox firmware up to date? Are the controllers up to date as well? At this point it sound software related. Did you tried to test other controllers as well?
par
Sounds like might be a little dirty and it is getting stuck and re-sending the input, without taking the controller apart it is hard to diagnose. Might want to try spraying some contact cleaner directly into where the sticks are and moving them around might break up whatever could be in there.
Indice 0
Ajouter une réponse
Thomas Mead sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 51
Total : 588
