Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Yellow light stable and no display
My PC getting on and the Yellow light is stable and no display. Asus Motherboard
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
I don't know what you mean by the yellow light.
I think it might be a debug light? But I don't know what the yellow light corresponds to. Could you tell me what's written below it? Boot, CPU, DRAM, VGA?
par Partager
Ajouter un commentaire
1 Réponse
Hi!
Assuming it is a yellow error code / debug light on your motherboard, then check your manual for debug/error/status/q-led lights for your specific motherboard.
I dunno if this is universal, but just checking a new asus manual, then the static yellow light is for DRAM (still, you have to check what codes are for your motherboard).
For (d)ram issues, please do the following:
  • Turn off your PC
  • Take out and the re-insert ALL ram sticks, then try starting your pc.
  • Otherwise, take out all ram sticks, and then try them one by one to see if any of the ram sticks works.
    • See your specific motherboard instruction manual for recommended single ram stick configuration, sometimes called "recommended memory configuration".
    • If the specific port does not work, attempt seating the ram sticks in the B1 slot.
  • Otherwise, if you have access to other fitting ram sticks, please try with them.
If you need instruction on how to re-seat your ram sticks. Search in your specific manual for DIMM or RAM installation.
If you need help finding the information in your specific motherboard manual, please post your specific motherboard model and we can help to point out specific pages.
If you specific motherboard manual says that the light/error code is for something else, please respond and we can guide you with that new information.
Good luck,
Cheers
Indice 0
Ajouter une réponse
Rasif TA sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 42
Total : 253
