Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriel de réparation et assistance pour la Mégane de 2ème génération de la marque Renault, également connue sous le nom de Mégane II.
It's about the car Renault Mégane 2/ 2008
How can i fix a problem in the steering wheel that is inflexible . When i want to turn it , i feel it so rigid and hard . I went to the mechanic to fixe it but he mentioned that the problem will not be solved if i will change the steering wheel . He said that ,probably , the problem is electric and it's not a piece to replace it .. please give me an advice to solve the problem.
Kind regards
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
3 commentaires
Thanks for replying i tried the troubleshooting mentioned in the renault workshop but no luck i think it's as u said i need to reprogram the EEPROM i'll try that
par
مخطط كهرباء مقصورة سيارة ميڤان 2007 2
par
مخطط فيشات داكرة السيارة الخرجية
par
Ajouter un commentaire
1 Réponse
Solution retenue
@rayayar we do not know what the mechanic checked nor do we know what the diagnosis is. Since you mentioned that it is electrical, use the wiring diagram #5 of the Renault Megane II Wiring Manual Check the fuses that are listed (F2, F5E etc.) as well as power on the steering pump itself. Changing the steering wheel will not resolve this issue.
To check your steering use the Megane 2 Power Assist Steering Fault Finding
Update (01/12/26)
@rayayar thank you for posting these codes. Those indicate the following issues:
DF035 - Variable power assisted steering motor - Internal electronic fault
- Intermittent
DF002 ECU 5640 No start assist or sudden loss with DAE fault indicator, STOP indicator and buzzer
Clear the codes using your scanner and see if that helps. There are lots of complaints about these particular errors on the Renault Forums. All of those seem to have issues with needing to reprogram the power steering EEPROM, in common. This may just be something where you want to get a Renault service involved. Of course, you should also try the troubleshooting as shown in the power assisted steering chapter of the workshop manual, as attached in the original answer
Indice 2
2 commentaires:
Thanks for answering my question
I have checked the fuses they are good
What do u mean by checking the power on the steering pump ?
The faults i got are df035 and df002
I have checked also the power on the cables and are 12v.
par
par
Ajouter une réponse
Raya yar sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 58
Total : 828
